For Sale Light and Motion Complete Package for Sony XR 520 HD Video Camera - $1,500 or best offer
Package includes:
- Camera
- Housing with Two Handles
- 1200 Lumen Video lights
- Two Chargers
- Batteries and Charger for Video Camera
- Integrated Pelican Travel Case
See Product Descriptions Below
Light & Motion Stingray G2 w/ White Balance and Menu Handle
The Stingray G2 housing has been carefully engineered with the primary goal of making it easy to learn and use for the new videographer. So simple to use, it makes capturing underwater video images a breeze. With the design benefits of non-penetrating electronic controls it eliminates the risk of housing leaks typical with mechanical through-hole designs. The included 2.7" high-resolution monitor back gives an easy view of what you're shooting. The modular camera trays allows the Stingray HD housing to adapt to numerous Sony CX & XR Series HD video cameras--while allowing accurate camera positioning to take advantage of Light & Motion's high quality housing.
Standard Features
• Multi-Camera Tray - Unique modular tray accommodates 13 Sony HD Camcorders
• 2.7" Monitor Back Included!
• Glass Zoom-Through front
• Ergonomic Non-Penetrating Electronic Camera Controls
• Self-Locking Rotating Latches
• Double O-ring Seals on both the monitor back and the lenses
• Records Photos to Memory Stick
• Ergonomic Grips, Right and Left handles Now Standards
• Easy-Load Self-Locking Camera Tray
• Moisture/Leak alarm
• Integrated Design for Battery Pods/Weight Brackets
• Quick Disconnect Mounts for Lights
• Record Indicator Light
Housing Controls
• Zoom +/-
• Record
• One Touch White Balance
• Auto/Manual Focus
DESCRIPTION
Light & Motion's new Sunray 1200 video lights literally take underwater lighting to a completely new level. You'll be able to capture video that wasn't possible before using the brightest, most rugged lights on the market.
• These 1200 lumen lights deliver light more reliably and efficiently than the HID lights they replace.
• Remarkably powerful, small, light and easy to use. These lights feature 1200 lumens per head and 90 minutes of burn time making these LED lights a natural for any video housing.
• This light kit comes with 2 LED lights heads, 2 battery pods, 2 batteries, 1 charger, and 2 arms for the Light & Motion video housings.
Design:
• The Sunray 1200 is assembled, depth tested and sealed at our factory. The LED emitters are rated for over 20,000 hour life. Never worry about bulbs failing again; the all solid state design has been field tested for over 1 year to insure your system will be the most reliable trouble free lights on the market. The advanced on-board software constantly monitors the thermal performance of the lighthead and drops it into low mode if it detects heat build-up, typical of a system left on out of water. Unlike many competitors designs, all our lights feature regulated power. This means our on-board software also monitors the battery and boosts the voltage as the battery drains to insure constant light output with no fading.
SPECS
• Beam Pattern: 85-degree. Custom machined reflectors create a wonderfully balanced even beam for great scene lighting.
• Power in Lumens: 1200. Over 1.5 times the light output of a 35-Watt halogen system!
• Color Temperature: ~6502 K
• System Weight: 3.9 lbs (1769 grams)
• Charge Time: 1 hour, 30 minutes
