Nikon 14-24 F2.8 in Ikelite setting
Started by MarcusMalta ·
  1. Hi,
    Has anyone ever tried to get the Nikon 14-24mm F2.8 in an Ikelite setting. Im on my way to upgrade to Full Frame and considering lenses and this seems to be the best Nikon wide angle underwater but it is not listed on the Ikelite Port Chart. I know that some of you guys improvise a way to get what the manufacturers don't sometimes so I will be holding to your answers. Thanks.
  2. I just measured a port extension for the modular Ikelite system, and it does not look like it will accommodate a 98mm diameter lens, so another reason you might want to reconsider trying to use the 14-24
