Extension Nauticam 16-35
Started by DuikKees ·
  1. Hi,
    I use the D750 in a Nauticam housing. I recently purchased a Sea&Sea 9,7" dome mainly to use with the 16-35 f4.
    What extension is recommended for this lens?
    The portchart from Nauticam says 90mm with the 9,5" Nauticam dome, but I also see others using the 70mm extension with this lens.
    Kees
  2. Hi Kees,
    I use the 8,5" dome with a 70mm extension with good results.
    --Rob
