SeaLife DC1400 w Dual Strobes and Video Light
Started by padi1029 ·
  1. DC1400 Sea Dragon Maxx Duo with Additional Sea Dragon Strobe and LOTS of extras.
    From Sealife website:
    The Ultimate Expandable Underwater Photography Package
    This set combines the DC1400 camera with Sea Dragon Flash and 2000 Lumen Photo/Video/Dive Light extended by Flex Arms, as well as the ultra-wide (weitwinkel) Fisheye Wide Angle Lens, making this the ultimate underwater photography package for any underwater environment. Quickly and easily expand the set with Flex-Connect - add grips, Flex Arms and other accessories with just a "click!.
    All of the essentials
    The DC1400 Sea Dragon Maxx Duo also includes a host of other accessories - such as a 16GB memory card, Charger Kit, Flash Diffuser, Moisture Muncher pack, rechargeable batteries, and spare o-rings - that all fit into the custom die-cut foam interior of an included hard case.
    SeaLife DC1400 camera:
    Piano Key controls for easy operation. 5 large buttons with big shutter and zooming lever for easy camera control, even with gloves on.
    Easy Set-up mode Easy 1-2-3 graphic on screen guide takes the guess work out of setting up the camera for great pictures.
    6 Underwater Modes for sharp, colorful underwater pictures under any conditions. Includes 4 built-in digital color correction filters.
    Spy Mode The camera automatically shoots continuous pictures at set time intervals (10 sec, 30 sec, 5 min, 30 min and 1 hour).
    Rubber armored, shock-resistant for rough handling and tough environments.
    Depth tested to 200 ft (60m) Guaranteed
    Manual shutter and aperture control in Ext Flash mode.
    No O-ring lubrication required Hassle-free O-ring maintenance, Just keep O-ring clean!
    HD Video mode Record continuous High Definition video with sound
    14 megapixel CCD for sharp, high-resolution pictures.
    26mm Fisheye Wide Angle lens. Get closer to the subject and fit everything into the picture.
    Super Macro Auto focus from 1 (2.5cm) to ∞
    Sea Dragon Flash:
    Universal - Works with SeaLife and other brands of underwater cameras
    Auto Mode automatically adjusts flash brightness for optimal image exposure
    Variable power adjustment allows user to manually fine-tune flash brightness for desired effect and image exposure
    Easy to expand with Flex-Connect trays, grip and Flex Arms
    Depth rated to 200 feet/60 meters
    Quick-release button to detach flash and aim in crevices and hard to reach areas
    Universal mount fits all SeaLife cameras and other brands of underwater cameras with standard tripod mount
    Auto Learn Mode easily syncs pre-flash with any digital camera
    Effective underwater distance range up to 8 feet/2.5 meters
    Approximately 150 flashes at full brightness with 4 AA batteries (not included)
    Waterproof battery compartment
    Sea Dragon 2000 Photo/Video/Dive Light:
    Powerful 2000 lumen LED light using the latest LED technology, featuring 6x CREE XPL LEDs
    One button control for easy operation - one button to power light on/off and select brightness
    Three brightness levels: 100%, 50% and 25%
    60 minute burn time at full power and constant brightness
    Depth rated to 200 feet/60 meters - Guaranteed
    Quick-release button to detach light and aim in crevices and hard to reach areas
    Auto Flash Detect Mode turns light off for 2 seconds when external flash is detected
    100° wide beam angle evenly illuminates the subject with no hot spots
    Corrosion-proof metal light head for heat dispersion and durability
    Removable Li-Ion battery w/ charger and international plug adapters included
    Universal mounting screw fits SeaLife and other brands of underwater cameras w/ standard ¼-20 tripod mount
    Included
    DC1400 14 megapixel digital camera and underwater housing, lanyards, camera pouches
    3 Rechargeable lithium ion camera batteries
    Fisheye Wide Angle Lens - wet or dry mount
    24 mm Wide Angle Lens - wet or dry mount
    Lens docks for both Wide Angle and Fisheye Wide Angle lenses
    2 Sea Dragon Flash heads with diffusers
    Sea Dragon 2000 Lumen Light Head
    Rechargeable battery and charging dock for Sea Dragon 2000 Light
    Cold Shoe Mount
    Two Flex-Connect Grips
    Two Flex-Connect Flex Arms
    Flex-Connect Dual Tray w/ standard ¼-20 mounting screw
    Flex-Connect Single Tray w/ standard 1/4-20 mounting screw
    16GB SD memory card
    2GB SD memory card
    PADI White Balance Card for manual adjustment
    DC1400 battery AC Adapter and charging tray
    Optical Cable and Universal Flash Link Adapter
    4 Spare O-rings (1 for DC1400 Housing, 3 for Sea Dragon light or flash), 3 tubes O-ring lubricant (for light and flash), O-ring removal tool
    1 package Moisture Munchers
    2, 3-packs of film screen protectors
    1, 5-piece Digital Camera Care Kit
    1 floating wrist strap
    Flash diffuser for camera on-board flash
    Instruction manuals
    Sea Dragon Maxx Hard Travel Case w foam inserts
    2 Soft-Sided Travel Cases (1-yellow, 1-black)
    Less than 1 year old with approximately 60 dives, except 24mm Wide Angle Lens which is 2 years old with over 100 dives. Camera, strobe and video light housings Never leaked. Excellent Condition, always well maintained and cared for. No scratches to housing front lens or rear viewing window. No scratches to Wide Angle and Fisheye Wide Angle lenses and seals good; never any condensation. Cases fit everything you need and then some.
    Camera takes great photos on land and underwater, and SUPER easy to use. Hate to part with it, especially since only purchased last summer...but needs change. Was fun to use over past year and everyone always remarked on great quality of photos.
    Asking $1250.00 (or best serious offer) + actual shipping costs. Insurance recommended and at additional cost at buyer discretion. Local pickup possible in Mercer County NJ area. PayPal accepted or COD if local pickup.
