Using the viewfinder is odd for sure. It was more difficult to compose pictures from atop the reef, so I tried to stay on the side of the reef and shoot from there.
The whole benefit of having an SLR (i.e. being able to look through the lens) is sort of wasted, since you can't see the entire frame through the viewfinder for properly composing your pictures. I'd say 85% or more of mine will require some cropping to get to shot I was going for. Even if it's just a slight crop to center the subject.
It's a bit heavy on land, and obviously takes up some serious boat real estate, making it a slight nuisance to others. I found a nice zip up colapsable cooler at Krogers that will fit my rig with dome. It fits from back to dome, and from handle to handle. I have to fold the strobes up and lay them on top of the housing.
The cooler also had rollers, so dragging it around made the camera burden much less.
Underwater the camera felt just like any other camera I've used. It didn't feel heavy at all, and was slightly negative without the lead weight.
All the controls are failry easy to operate, but I've come to learn that I have no freaking clue what I'm doing with manual strobe operation. I should have read up on that more. Also I'm having a hell of time manually aiming the DS125's for some reason, where-as I never had a problem aiming my Inon D180. Not sure what the deal was there.
There was one really really strange thing that happened to me a few times, and at one point during a complete dive.
First the LCD quit displaying the last picture I took. So I'd try to go into the menu. No luck. Try pressing the PLAY button, nothing. Then the camera would act like it was buffering pictures. I shot an entire dive blind with no feedback from the LCD. Man, shooting film must SUCK!
The other thing I noticed was that when the LCD was working, the displayed picture would not go away automatically while at depth. Not even when I'd press the PLAY button. Only hitting the shutter release, while out of focus, would the picture go away.
Also, the dual cords being connected to the manual controllers leaves a lot of slack that really gets in the way of things.
One thing that I didn't really figure out until the end of the trip, is that using the same apeture settings that I would use with my 5050 don't really jive with what you use with the D70. F6.3 did not provide the depth of field most of my pictures needed. So a good number of my pictures look a bit blurry because the sharpest part of the photo is not the main focal point of the picture. That was my fault. You'll notice those last pictures shot at F10 look much better then the others I posted.
I don't think I ever used an apeture higher than F10 the whole trip, and I used -3 or lower on the manual controller for both strobes most of the time.
I should have used a much higher apeture, and more strobe power, and I think I would have quadrupled my number of keepers.
Well, I have until October to think about how to improve.
