FS: Panasonic 7-14 F/4
Started by SkiSwami ·
  1. Price: $595.00
    Payment method: PayPal
    Item condition: 9+ Shows little or no signs of wear
    Shipping instructions: CONUS ONLY via USPS Priority Mail
    Mint Condition. Very little use and works/focuses perfectly. Glass is flawless. No Case, but box, caps and Instruction book included. BIG BONUS >>> I have added the "Olympus Modification." This is the addition of a filter holder (from the Panny 8mm Fisheye), to the rear of the lens in order to add a gel filter. This helps eliminate the occasional, known issue of purple fringing or purple blobs when used on some OLY cameras. (Not an issue on Panny cameras) The holder and filter are visible in the photos and obviously, you can insert or remove the filters easily.
    Right now I have the Kodak Wratten 2E Filter inserted, which is a slight bit too yellow, but can be corrected for. The recommended filter is the 2A. A bit hard to find, but often available on eBay or other forums. Great Lens, but I decided to get the OLY f/2.8 7-14 instead.
    If you want more info on the purple fringing problem, and how well the filter works, you can read this: http://alanwatsonforster.org/writing/mft-purple.html
  2. LENS IS SOLD!
