FS: Olympus E-PL3 and housing
Started by sjwhite26 ·
  1. Hi all
    The second round after the clear out!
    I have an Olympus E-PL3 (part of the m43 range) and the Olympus housing PT-EP05L to sell hopefully as a set for someone who is either starting out or wants to move up from a compact. I really enjoyed this set and photographs taken with this set can be seen here, here, here and here. I would recommend a strobe to go with this system. £475 the set plus postage (UK and Europe).
    Olympus E-PL3 camera
    Originally purchased in August 2012 this was my first camera with interchangeable lenses. Note the lcd screen has some light micro scratches that are only visible in bright light.
    The set is a double zoom kit with:
    E-PL3 camera in red
    14-42mm lens (M.Zuiko 3.5-5.6)
    40-150mm lens (M. Zuiko 4.0-5.6)
    Flash
    Original battery
    Non-OEM battery
    Charger
    USB cable
    AV cable
    Strap
    CD-ROM
    Manual
    Original box
    Olympus PT-EP05L housing
    Originally purchased in August 2012 along with the camera. Note there are some light scratches on the back of the housing, these do not impact ability to view the lcd or photographs, there are no scratches on the front of the port. Also the housing appears to be permanently attached to the ultralight tray that I used for a strobe, again it does not impact the photographs and in fact aids when holding the system and is where I added the arm for my strobe.
    Olympus Housing
    2 x o-rings (original, plus a new and unused oem spare)
    Anti-reflection for the 14-42mm lens
    Gear for 14-42mm lens
    Flash diffuser
    Ultralight tray TR-D
    Ultralight AC-H handle and ball
  2. Is the 40-150 lens just for topside? Ie it doesn't fit in the housing or have zoom gear?
  3. Is the 40-150 lens just for topside? Ie it doesn't fit in the housing or have zoom gear?
    Hi
    That is right, the port doesn't fit the 40-150mm lens its too long.
  4. Still available
