Olympus Pt-E06L With AOI Acrylic Semi-Dome Port DLP-04P
Started by Vimal ·
  1. Hi,
    I recently got into underwater photography.
    I use a Olympus camera E-PM1 in Olympus Pt-E06L housing with 14-42mm lens.
    I looking at changing the port to AOI Acrylic Semi-Dome Port DLP-04P which
    can accomodate lenses like 14-42mm, 9-18mm lens and also 60mm Macro lens.
    Has anyone tried this port on their Olympus housing with different lens combo.
    How was the results ? Is it worth a investment for using with wide and macro lenses?
    Thanks in advance for your time.
  2. Hello! I haven't used the AOI port. However, I am selling a Zen glass port & Oly 9-18mm lens. I used it twice and also used it with my Oly 60mm macro. Both lenses produced quality images with the port.
    If you're interested, please shoot me a message
    Cheers.
  3. Hi Chris,
    Thanks for pointing to the other thread. Lot of info there.
    As I am just starting in uw photography and budget was a constraint, AOI with half the price tag of ZEN looked
    like a good option.
    My main worries are
    1)Image quality when shooting with 9-18mm wide and 60mm macro. Looking for a reasonable quality with low priced port.
    2)Working distance while using 60mm macro in the semi-dome port.
    I am guessing working distance will be more compared to dedicated Macro port and
    also I wont be able to add any macro wet lens later.
    Did you had any limitation in working with Zen semi-dome port and 60mm macro combo ?
    Hi Kent,
    Thanks for the info. I will message you.
  4. For half the price, I'd probably go with the AOI.
    I never was able to find exact specs for comparison, but I think they are essentially the same.
    No, you won't be able to add a diopter, but with the 60mm, you really don't need it. That's 120mm effective. It's a very zoomed it narrow view. In fact, I have to back off many times to get what I want in the frame.
    I'm really a huge advocate of this port with the 9-18 & 60. So much versatility with just a lens change and leave the port alone.
    I got the port for the 8mm specifically to shoot whale sharks. I've enjoyed it and used it for other things also like over & under shots.
    But the last dive trip I took, I used the 9-18, 60 combo 90% of the time.
  5. Thanks Chris. That was very helpful.
    Switiching between the wide and macro lenses without switching the port is a great advantage.
  6. I would check with Kent.
    you might get best of both worlds, nice glass port for less money.
    I bought my Zen used from someone and it's still like new, 5 years later.
    Edited by chris_l
  7. Vimal
    Check you PM for my reply
