For Sale: Aquatica ports and Sea & Sea strobes
Started by pokumura ·
  1. I upgraded my camera gear and I have too much camera stuff around the house. Things can be sold separately, and buyer pays shipping. I live in Hawaii, so if you need it fast it will cost a little bit more. I have had this gear for a long time. I bought the housing used, and I have used it almost every day for the past two years. Some of the outside coating paint is chipped off but it does not effect the housing. Definitely a good camera housing for somebody looking to get into underwater photography as a hobby. The A20 housing is discontinued and the bulkheads for the strobes do not work and parts are unavailable :( . The ports (except 8 in) are all in good shape, just minor nicks on the outsides, glass is good. The 8 inch dome has some wear on its surface. I also have resealed it using 5200. The glass separated from the metal a year ago when I was hiking into a beach and early in the morning and when I hiked out it was 20 degrees hotter and the air inside had expanded and separated it. You can see the glue (white) in the picture. I still use it. I free dive down to 60+ feet with it and it holds up. Still good for over-unders, but it could use a good polishing. The strobes work great. One had a battery explode in it 3 years ago, but after cleaning it has not had any problems. For more pictures of certain items just let me know.
    Aquatica:
    - A20 housing comes with canon 20D body $BO
    - mini dome (18410) $600
    - macro port for Canon 60mm (18429) $300
    - back port cover (18790) $50
    - port extension ring (18456) $200
    - port extension ring (18457) $200
    - zoom gear for tokina 10-17 $100
    - 8in dome port with shade $150
    - 5-pin sync cords x3 $100 each
    - Pair of YS-90 Duo strobes $500
  2. Hi
    Are these strobes fibre optic compatible?
  3. Yes, I bought them used and they did not come with the cables. I think they connect to a different diffuser.
  4. Hi,
    May have clicked wrong listing. Did you respond via michaellamanson? If so I'll take strobes. Thx!
