Optical Trigger problems with Nauticam/Nikon...UWTechnics and Nauticam
Started by sshanmuga ·
  • 9Posts
  • 9Replies
  1. I have a Nikon D4 and a Nauticam housing, with the S&S YS-01 strobes. I ordered a Nauticam optical trigger and nauticam fiber optic cables, and found out that the optical trigger works inconsistently with the YS-01 strobes, in that it doesn't trigger the strobes to fire.
    The UWTechnics TTL trigger says it works with YS-01 strobes, has anyone on here tried the UWTechnics trigger with the YS-01 strobes?
    Edited by sshanmuga
  2. From the UW Technics manual :
    Compatible photo cameras: all Nikon DSLR cameras
    • Compatible underwater housings: NAUTICAM housings for Nikon D600/610, D7100, D7200, D800/E, D810, D4/s
    • Compatible TTL strobes: Inon Z-240, Sea&Sea YS-D1, YS-D2
    • TTL outputs: 2 optical, 2 electric wire
    • Maximum Fiber-optic cable length for “TTL” operation: 3m
  3.
    thanks!
  4. Has anyone had issues with the Nauticam optical trigger and YS-D1 strobes?
  5. I have had problems get a fibre cable to be consistent with a POS and Inon strobe. Things I found:
    - the fibre needs to have good 'clean' ends
    - the alignment needs to be positive, that is the fibre needs to point at the light/sensor capture maximum light and direct this to the sensor.
    - the fibre needs to be firmly held (so it says in optimal position)
    - camera strobe needs to be 'bright', I wouldn't turn the flash down as some cameras allow.
    I tried three alternate fibres with different cap ends only one works well.
  6. I have had problems get a fibre cable to be consistent with a POS and Inon strobe. Things I found:
    Have you ever tried multicore cable?
  7. No
