Battery Corrosion on ys-250
Started by clernix ·
  1. I have some battery corrosion on the connection pins of my ys-250. What is the best way to clean that off?
  2. Rubbing it off gently with a pencil eraser is a good first attempt. Using q-tips and rubbing alcohol helps clean off corrosion and dirt off the housing plastic areas.
