Inon S2000 and Sea & Sea YS-01
Started by UwDanny ·
  1. Hello everyone,
    I have a camera with a singel Inon S200 flash and am willing to expand. I have a limited budget and found an secondhanded Sea &Sea YS-01 flas for a good price. The flash is only used 20 times so it is as good as new.
    I was wondering if it is posible to use the Inon s2000 and the Sea & Sea YS-01 flash at the same time? Has anyone experience with this or a usefull thought? I know the warmth of the light has a difference of 150k between the to, but will this be a problem?
    I do both macro and wide angle shooting if that information helps :)
    Thanks in advanced,
    Greatings from the netherlands,
    Danny.
  2. Hi... just want to ask. How did you find your S2000 for wide angle??
    Also, how is the TTL worked with FO cable and flash sync..?
    Sent from my SM-N9005 using Tapatalk
  3. Hello Timz,
    The S2000 is a very nice flash. When using wide angle is use it on full power manual. The TTL works great, when not doing wide angle i set my camera on 'fill-in flash' (don't know is this is translated correctly, but it is the mode were the camera decides how strong it needs to flash), and i practically never need to adjust anything. The flash is connected via the FO cable and works 100% of the time!!
    Greating Danny.
  4. To the OP, works fine; there is a small difference in color temperatures but should not at all be a problem.
    Bill
  5. Hello Bill,
    Thanx for the reaction. I think that i'm going to buy the flash in that case.
    Greating Danny.
  6. I have bought the second flash, and it works great!! Unfortunately my old flash, the inon s2000, broke the second dive i did whit the two flashes.....
    The repair is going to cost €250,-... so i don't know if i'm going to fix it right away.
