Nauticam NA-A7 Housing, body, lens, ports, strobes ++ complete kit
Started by thebiodiversitygroup ·
  1. 100% of your Purchase Supports The Biodiversity Group
    COMPLETE Sony a7R Camera and Nauticam Underwater Housing Kit
    $5,980
    Retail Price $8,365
    This kit includes absolutely everything you will need to start shooting underwater.
    The Nauticam housing is a premiere brand—see housing description below.
    · This kit comes with the famed Sony a7R 36.3 megapixel full frame camera body with bonus battery grip and tripod L-mount (grip and mount for use topside only without housing).
    · You get the body in the original box with original battery, charger, and extra battery, and a 32GB SD Card. This kit comes with the versatile Sony FE 28-70mm lens with image stabilization.
    · The two Sea&Sea strobes come with fiber optic connectors, arms and clamps. The Nauticam Flash Sync is used to connect the camera body with the fiber optic connectors.
    · Included are two lens ports, one for the included 28-70mm lens, and another for the (not included, but awesome!) Sony 90mm macro. The zoom gear works on the 28-70mm lens and port.
    · Everything is perfectly functioning. All optics are clear.
    · Items are classified as good to very good condition cosmetically.
    Item
    Retail
    Sony a7R Camera Body with battery, charger, strap, manual, software in original box
    $2,400
    Sony SEL2870 FE 28-70mm F3.5-5.6 OSS Lens
    $498
    NA-A7 Nauticam Housing
    $2850
    Nauticam N100 Port for 90mm Macro
    $410
    Nauticam N100 Flat Port 74 for Sony FE 28-70mm
    $380
    Zoom gear for Sony FE 28-70mm
    $260
    Nauticam Flash Sync
    $220
    Fiber Optic Sync Cords
    $160
    Sea&Sea YS-02 Strobes
    $838
    Arms and Clamps
    $250
    Battery Grip and L-bracket for tripod (topside use only!)
    $90
    Extra Battery and 32GB SD card
    $40
    Total Retail Price
    $8,396
    post-54131-0-79151700-1471993052_thumb.jpgpost-54131-0-29934600-1471993053_thumb.jpgpost-54131-0-84751900-1471993053_thumb.jpgpost-54131-0-84751900-1471993053_thumb.jpgpost-54131-0-32557200-1471993054_thumb.jpgpost-54131-0-88477100-1471993054_thumb.jpgpost-54131-0-55352000-1471993076_thumb.jpgpost-54131-0-28231600-1471993084_thumb.jpg
    Please contact me for questions!
    From Nauticam Website:
    NA-A7 housing for Sony A7/ A7R/7S camera
    Nauticam has released details of their new housing for the Sony A7 and A7R cameras. The NA-7 has a switch that allows the user to choose either LCD or EVF and a Nikonos 5 pin bulkhead. Perhaps most interestingly, Nauticam are producing a Nikonos adaptor, allowing the use of the Sea & Sea 12mm fisheye or Nikonos 15mm lenses.
    Housing for Sony A7 and A7R/A7S
    Innovation Underwater
    Nauticam produces the world’s widest range of rugged aluminum underwater camera housings and related accessories. There are cameras to suit every photographer from very capable compacts to medium format to professional cinema systems. Of all of those cameras, there has never been one quite like the Sony A7 and it’s high pixel count sibling, the A7R. Sony has melded a full frame (36mm x 24mm) sensor into a camera body that is essentially the same size as many “compact” cameras. The result is a stunning blend of high resolution image quality and compactness.
    Sony A7R with Nikonos 15mm
    From a distance, the Nauticam’s A7 offering looks like one of the company’s SLR housings, but looking closer, one can see that the Nauticam designers have managed to squeeze all of the engineering and ergonomics of those housings into a considerably smaller package. It only makes sense that the housing should be appreciably smaller than an SLR housing given that is one of the prime advantages of the camera.
    The NA-A7 Housing
    The new housing for the A7 delivers on the promise of the A7: Full frame camera - small package. A new port system was designed for this camera… the SLR port opening was too large, meaning that the housing would be too large, and the existing mirrorless system port opening is too small for some of the lenses expected in the new Sony FE lens lineup. So, a new line of intermediate size ports is required and is being delivered with this housing.
    The housing and new port line would not be complete with the patented Locking Port Release system, which, like it does on other Nauticam housings, utilizes a unique internal bayonet system that locks the port securely without twisting or misalignment. The iconic red lever is easy to operate and lets the shooter know immediately that the port is securely locked in place. The user friendly housing latches are here as well, making this housing exceptionally easy to put together.
    The patent pending EVF/LCD switch allows a quick way to alternate between using the large bright LCD display or the high resolution electronic viewfinder (EVF). The housing ships with a standard .66x viewfinder for the EVF, which is easily swapped out for either of the two Nauticam enhanced viewfinders.
    The NA-A7 includes a pre-installed Nikonos style 5-pin bulkhead with universal hotshoe connection (x and ground connection only) installed, enabling manual control of the most commonly available strobes, such as the Inon Z-240 or Sea&Sea YS-D1. Additional strobe firing options will be announced at a later date.
    Integrated Electronic Vacuum Check and Leak Detection System
    The NA-A7 ships with Nauticam’s new vacuum system with integrated electronic vacuum and leak detection monitoring system for extra piece of mind. A simple coded LED lighting system lets the user know that the watertight integrity is solid. The NA-A7 ships with a bulkhead port for installing the optional vacuum valves.
    Key NA-A7 Features:
    Signature Nauticam Port Locking System: The iconic red locking lever is right at home on the NA-A7… lens/port changes made quick, easy and secure.
    SLR Styling with Handles Built In: The housing is designed to be used with the shooter’s hands on the handles, ergonomically placing the camera controls at just the right spot for easy use. No extra tray/handles to buy!
    Brackets: Laser cut stainless steel brackets reinforce the handles, making the rig sturdy and stable even with large strobes or video lights. Mounting balls are included, ready to attach strobes, video lights, and more.
    Vacuum System: The integrated vacuum check and leak detection system adds extra assurance of watertight integrity. Use it without an optional vacuum valve and it serves as a audible/visual water ingress detector. Add the vacuum valve, and get watertight integrity indication via a color coded LED light.
    LCD or EVF - Your Choice: The patented switch means either the LCD or EVF can be used and the shooter can instantly switch between them - underwater!
    EVF Viewfinder Options: For shooters wanting to take the ultimate advantage of the excellent OLED EVF in the A7, the renowned 180º Enhanced Viewfinder or the excellent 45º Enhanced Viewfinder are available. It takes less than a minute to change these viewfinders and no tools are required.
    Fingertip Control: Fingertip control for all key shooting controls, including both shutter release, focus lock, both command dials, and video start/stop. All of the controls are easy to operate, even with gloves on.
    Rubberized Zoom/Focus Knob: The new zoom/focus knob is now rubberized to make gripping easier and more comfortable. Nauticam is the only housing manufacturer offering over-molded, rubberized parts. Like previous Nauticam handles, the built-in NA-A7 handles get the rubberized treatment that so many shooters have come to enjoy.
    Nikonos Lens Support: Old meets new as the Nikonos lenses finally get matched up with a digital camera that is worthy of these legendary water contact lenses.
    Despite the small size, this is a very easy housing to operate, even with gloves on. Every control is placed where a underwater shooter wants it - after all, the design team are underwater photographers themselves and strive to make every Nauticam housing the most ergonomic available. Each control, whether it is to change aperture or shutter speed, access the autofocus lock, change ISO, or even play back, is given consideration to minimize movement and make shooting easier.
    Of course, the sort of quality and robustness that has become synonymous with the Nauticam name is present with this housing as well. Milled from solid aluminum, the housing is depth rated at 100m and built to last. Exceptional care is taken to reduce any possibility of galvanic corrosion, and the housing is hard anodized to stay looking great after years of use.
  2. Now offering free shipping :)
  3. Hi
    I'm interested in the set.
    Any idea regarding postage to Spain with insurance?
    Martin
    Marvass@hotmail.com
    Enviado desde mi SM-G920F mediante Tapatalk
  4. I could use this stuff:
    $498
    $2850
    $410
    $380
    I don't have a use for the camera, strobes, arms.
    PM me if you'd consider breaking it up.
