Dome port reflection?
Started by BC83 ·
  • 16Posts
  • 16Replies
  1. I am using a canon 60d with an NA60D, Tomkina 10-17, 20mm extension and 8 inch dome
    When shooting at the wider end I am getting a reflection I think in the dome that's at the top of the images. The reflection is being generated from the internal flash
    As I zoom the lens the reflection move further out until it disappears at 14mm
    I don't think it's a scratch issue as its to uniform with an arch then 3 Marlena either side, plus its symmetrical and also if I mount the port upside down its still there
    How can I resolve this?
    Take a look at the top of the image in the deter and either side of the arched mark
    Look forward to getting some help!
  2. U can try to stuff foam/sponge around the lens to prevent light from causing the relfection
    Sent from my SM-N930F using Tapatalk
  3. U can try to stuff foam/sponge around the lens to prevent light from causing the relfection
    Thanks for your reply
    Is this a common problem?
    Byron
  4. yes it is. You can make a ring to fit around the lens that fills up the port.
  5. Yep, I have the same problem with a Sigma 15mm and a Subal 230 dome.
    I thought I'd tape over the area on the lens with electrical tape.
  6. Ok cool, sounds like a nice easy solution. I must say I find it a little baffling that given the costs of ports, housings etc that this is a common issue. You would have thought the manufacturers would have resolved this
  7. Has anyone got any examples (Pictures) of methods they have used to resolve this?
    Byron
  8. I had the same issue after shaving the lens hood off my Tokina 10-17mm. I coloured the silver parts in with black permanent marker and this helped resolve the issue.
  9. I have bought the skirt already made.
    (See Neoprene Light Blocking Mask on the link
    http://aquatica.ca/en/accessories_misc.html)
    Wow, that's a pretty neat bit of equipment! What was the price, pbalves? I couldn't see one on the website.
  10. This one is for the Tokina 10-17 FE in Aquatica port
    Probably it works on other ports if they have the internal diameter equal or smaller than the aquatica one
  11. Great stuff guys, just what I was after. Cheers
    I shall make one tomorrow with one of the old drysuits!
  12. The Nexus mini-dome 1017 for the Tokina 10-17 has an internal baffle fitting that avoids this problem.
    with other domes, I use soft foam cut to fit around the lens and inside the dome/port, same as mentioned above.
    I think I found the foam at a hobby store.
