Flash triggers???
Started by balexandrescu ·
Flash triggers???
  1. I use a Nauticam housing for my E-M1 with the small included Olympus flash. Does anyone have any experience in using flash triggers with this setup? I'm primarily interested in extending the battery life of my E-M1 as I don't like to open my housing all that often in between dives. I currently set my flash to 1/64th and shoot my Inon Z-240's in manual mode. I still use the S-TTL occasionally. Thanks!
  2. I am using Hedwig's flash trigger successfully with the EM-1 and a whole bunch of different strobes (Inon and Sea & Sea). Works like a charm BUT you will need to mess around with the LEDs on the trigger to get them to flash only in the window.
    Bill
  3. I am using Hedwig's flash trigger successfully with the EM-1
    Hi bvanant,
    If you could you post a photo of the trigger instaled on the camera and the housing, could be great!
    Thanks in advance
