FS: Sea and Sea YS-01
Started by Fred6944 ·
  1. This strobe has been used a couple of times in some surge prone, rocky places which explains the scratches. Otherwise it is in perfect working order and ready to add to a camera. This model comes with digital TTL.
    Asking price: $250post-47589-0-46933600-1473798609_thumb.jpgpost-47589-0-80887700-1473798534_thumb.jpgpost-47589-0-21969700-1473798534_thumb.jpg
  2. Hi there - could you let me know if (a) this will work with a Sony rx100? And (b) all the parts (cable, diffuser,etc) are supplied? Also, could you let me know rough postage cost to Australia (Sydney). Thanks! David
  3. The answer to your question is dependent on the housing you are using. I can tell you that if you are able to use an onboard flash this strobe will work just fine as it has a slave mode. The other option is to use a sea and sea fiber optic cable and switch to the digital TTL mode. I don't know which rx-100 housing you have but I have found model that possess the necessary input to use this mode. As far as parts go, the diffuser is attached in the photos. There are no cables as I used this flash is slave mode only but the cables are readily available. The strobe has never flooded and works perfectly. The rough postage would be $35 US. Let me know if you have any other questions.
    Fiber Optic Strobe Cable
    http://www.backscatter.com/sku/ss-50133.lasso
    Rx-100 with Fiber Optic Cable (for example)
    http://www.backscatter.com/sku/bs-rx1003-pkg.lasso
  4. Bump.
