7.5mm F2.0 Laowa lens for MFT cameras
Started by Davide DB ·
  1. Is this the prime lens we were waiting for as alternative to 7-14mm?
    Unfortunately is a manual lens but it shouldn't be a problem with this FOW.
    • 110 degrees FOV
    • 12cm minimum focusing distance
    • manual focus
    • 49mm filter
    • 50x55mm
    • 170g weight only
    Full press here:
    http://www.personal-view.com/talks/discussion/comment/223237
  2. Looks good!
    Should be sharp, being a prime.
    I wonder if it got any electrical contact with the camera, so you can adjust aperture in camera, instead of using the aperture ring - that would be a pain if not.
  3. I wonder if it got any electrical contact with the camera, so you can adjust aperture in camera, instead of using the aperture ring - that would be a pain if not.
    I checked and... unfortunately is completely manual :fool:
    RIP
  4. What a shame. So we are back with the Panasonic and Olympus 7-14mm...
  5. With the emerge of the WWL-1, I am leaning towards the wet-lenses. The wwl-1 specifically is not perfect (heavy and can't be selected rectilinear as the optically inferior inon h100), but I hope there will be serious development efforts here.
