Inon wide angle problem
Started by Irwin ·
  1. Inon wide angle problem
    I have a Inon UWL-100 on an Ikelite housing with an Oly 4040.
    I've gotten really good results with it that I can no longer reproduce. Instead of wide angle shots I'm getting serious distortion in all but the middle of the image.
    I have to believe that I should have the camera wide but actually zoomed, or perhaps it's an f-stop issue.
    How should this thing be used?
    -Irwin
  2. If you zoom with the wide angle you will get serious blurring. Higher f stops will reduce, but not eliminate the blurring.
    Bottom line: Do not zoom with the wide angle lens on the camera.
    Note: With the INON dome you can zoom and get only a minor amount of blurring in the corners.
  3. No problem!
    Hi Irwin
    I have the Inon UWL-100 attached to my Canon S45 with Canon WP-DC300 housing. I have no experience of any blurring/distortion throughout the full zoom range of the camera.
    I have recently bought the Inon UCL-165 macro lens and have found all the images (zoomed or not) to have perfect centre focus with blurred edges. I think this is because the S45 has a smallest aperture of f8 which does not really give the depth of field needed. So the lens was a bit of a waste of money with this camera!
    But again, not even a hint of a problem with the wide angle! I often zoom with the wide angle for shy subjects. Being a relative amatuer I have no solution for you, save to suggest it might not be the lens.
    Regards
    Jean.
  4. Yep - staying wide did it. I don't know why I didn't realize that last I tried. Thanks.
