Help with my Sony/Fantasea - which strobes?
Started by my2cents ·
  1. Hi!
    I am about to buy a small setup for doing underwater babyswimming photography in a local pool. Water depth will be max 1m (babies after all) and the existing indoor lighting is good. However, to avoid backscatter I understand one or two strobes would help a lot. Appx. 120-150 images will be taken during an afternoon. Max 1.5m away from the subject.
    So here is a possible setup;
    Sony RX100 iii/iv
    Fantasea housing for the Sony
    Sea&Sea YS-03 or YS-01 (either one or two strobes?) kit
    I believe the above will suffice, but am happy to hear you comments.
    Thanks!
    Edited by my2cents
  2. Hi,
    setup will be fine,
    but maybe you should think about a wet wide angle lens.
    Get as close as you can, and there the 24mm of the camera lens will not be wide enought.
    Regards,
    Wolfgang
