Using Olympus 60mm macro in Nauticam 12-50 flat port
Started by Draq ·
  1. Has anyone tried using the Olympus 60mm macro lens in the Nauticam 12-50 port? Just playing with it, it seems to work out, although it is just ‘slightly shorter than the 12-50 lens. I have not tried this in the water but it seems it should work fine.
  2. Hi,
    i used it the originally macro port, but the 12 -50mm as well.
    Was not a problem.
    Regards,
    Wolfgang
  3. Yes. I use it this way regularly. It works perfectly.
  4. Thanks for the responses. Will simplify port selections when traveling.
  5. Yep, I use the Olympus 60 mm macro in the 12-50 port. Works fine. (Oly EM5 Mark I).
  6. I've used the Olympus 60mm in the Nauticam Flat Port 72 (for Sony NEX 18-55mm Lens & Panasonic 14-42mm Lens) and it works fine. The only thing I found is that because the 60mm is such a close-up lens, finding and framing your object can be quite tricky - particularly with a larger-than-needed port. Eventually I went and bought the correct port, which was smaller, and therefore much easier to work out where the lens was pointing!
