Nauticam Nikon 12-24 gear on 10-24 lens...
Started by PeteAtkinson ·
  1. Does the Nauticam gear for the Nikkor 12-24mm DX lens work perfectly with the Nikkor 10-24mm? Anyone tried it? Thanks!
  2. I did and it fits. The plastic inner ring is aprox. 5mm thinner (top to bottom) so you may use some plastic strap to fill the space but if you have all those tiny rubber spacers it holds on it's place.
