FS: Nauticam M16 #25612 Vacuum Valve ; #25221 M10 ball mount, 2 x ULCS DB-BL08 Buoyancy Arm
Started by ameyer ·
  • 16Posts
  • 16Replies
  1. Hi all,
    selling some accessories on ebay, for more pictures, prices and more details please click here:
    http://www.ebay.de/sch/a.my/m.html?item=332011870652&hash=item4d4d7319bc%3Ag%3APN4AAOSwm0JYDO0E&rt=nc&_trksid=p2047675.l2562
    e.g. Nauticam M16 Vakuumventil #25612 Vacuum Valve 150 Euro or best offer (Retails at 238 Euro)
    Items located in Germany, worldwide shipping possible, payment by PayPal or to be picked up at Frankfurt/ Main (Germany)
    Kind regards,
    Andreas
  2. Bump
    2 days left ......
    selling some accessories on ebay, starting at 1 €, for more pictures and details please click here:
    http://www.ebay.de/sch/a.my/m.html?item=332045378997&hash=item4d4f7265b5%3Ag%3Auv4AAOSwal5YLw53&rt=nc&_trksid=p2047675.l2562
    e.g.
    Nauticam M10 Strobe Mounting Ball
    ULCS DB-BL08 Buoyancy Arm (2 pcs), 203mm
    Kind regards,
    Andreas
    Edited by ameyer
  3. Hi, still available
    Nauticam M16 #25612 Vacuum Valve (Bulkhead & Pump)
    Nauticam M10 Strobe Mounting Ball SOLD
    Kind regards,
    Andreas
  4. Hi, is the Vacuum Valve still available? If so I'd like to buy it. You can reach me at mlanghan@ucsc.edu
  5. bump
  6. Im keen to buy the vacuum valve. How difficult/easy is the install??
  7. Hi, it´s very easy.
    Please provide me with your housing model number and I will check for you if the M16 vacuum bulkhead will fit or if you need the M14 one.
    Kind regards,
    Andreas
  8. I have the nauticam NA7D housing. In pretty sure it will fit. Did you use it with the electronic leak detection system? Or did you just try and open the housing to be sure it was vacuum sealed?
  9. Yes, it will fit, you can check it also over here on the Nauticam Vacuum check and Leak Detection System Compatibility Chart:
    http://downloads.brasilmergulho.com/Manuais%20e%20Diagramas%20de%20Equipamentos/Fabricantes%20F%20-%20O/Nauticam/Vacuum%20check%20Chart.pdf
    And I used it on my Nauticam NA-EM 5II housing with the electronic leak detection System, working perfect.
    Selling it, cause i changed to the M16 vacuum bulkhead extended Version, with additional HDMI Bulkhead to have the vacuum System still available plus the possibilitie to connect a external HDMI Monitor.
    Kind regards,
    Andreas
  10. Hi, shipping cost worldwide, priority and registered, will be 9,50
  11. Cheers for the prompt replies. im actually in the south of france, a place called pau. i am definitely interested, i just need to set up another paypal account thats linked to my french account so that i dont pay all of the conversion fees. I should be able to get it done today. Ill be in touch with you later this afternoon or tonight. Cheers @ameyer
  12. How you doin @ameyer i have set up my paypal account. Where do we go from here? You can contact me on +33771796626 or at uri.hancock@gmail.com
  13. Hi uri.nacock.
    Send you E-Mail to uri.hancock@gmail.com
    Kind regards, Andreas
  14.
    ULCS DB-BL08 Buoyancy Arm (2 pcs), 203mm STILL AVAILABLE
    Nauticam M16 #25612 Vacuum Valve (Bulkhead & Pump) SOLD
  15. My M16 vacuum seal valve arrived safely. ☺☺
