FS: Light & Motion SOLA Video Pro 8000 FC Light
Started by damcue ·
  1. Still new in the box. The box has some shelf wear. It includes the following items:
    -24v Power Supply
    -Sola Pro Ball Mount
    -Allen Key
    -Neoprene Sleeve
    I am asking $999 shipped within the continental U.S.
    • -8000 lumen output certified to the FL-1 Standard.
    • -OLED Dashboard Display for monitoring settings, battery life, etc. Removable front LED array allows for safe travel.
    • -FC stands for - Fast Charge the Li-ion battery completely in 1hr 45 min.
    Main Specs:
    • Model Name: SOLA Video Pro 8000 FC Black
    • Lumens: 8000
    • Beam Angle: 90 Deg
    • Battery Type: Internal Lithium Ion
    • Max Burn Time: High- 50min / Med- 100min / Low- 800 min
    • Lumen Range: 3000+
    Sola lights have a factory sealed body so you never need to worry about flooding. Control is accomplished with a magnetic slider on the top of the body. Slide forward or back to turn on. Hold forward or back to turn off. Rotate to lock. Slide forward to increments the power levels.
    SYSTEM WEIGHT: 984 Gr.
    SIZE: 5.5" x 3.5" x 3.5"
  2. I'm also open to reasonable offers.
  3. Would you trade this for anything?
