Ikelite Housing, Strobes, Ports, Tubes, etc
Started by jonnywhatever ·
  1. Mulitple Ikelite items - used less than 20 times - haven't used x 2 years. Shipping is in parenthesis, Continental USA only
    1. Ikelite housing: Canon EOS 5D Mark III, 5DS, 5DS R DSLR Underwater TTL Housing by Ikelite 6871.03: $1100.00 (shipping $45)
    Item barely used, literally just 20 dives (if that). I just don't use it (and need the money :). This has TTL, worked great. It can fit a canon 5d mark iii, 5ds and a 5dsr. Please note, this is the version of the housing built specifically for the 5d mark iii (6871.03, not the 6871.04 - not sure if that makes a difference, although it might when using 5ds or 5dsr with ttl? it was built before those models came out.) There are no scratches, and comes with everything you see.
    2. DS160 Strobe x 2, 3 batteries (li-ion), dual splitter cable, one arm: $1100.00 (shipping $65.00)
    These strobes have not been used much at all, less than 20 dives. They are in excellent condition, comes with everything in the photos:
    • 2 x Ikelite ds 160 strobes - diffusers and ball mount (cost new $799 each with 1 battery) - please note, there are 2 diffusers, one for each strobe, although in the main picture I forgot to put the 2nd in - it is in the individual images
    • 3 x Ikelite batteries for ds 160 strobes, li-ion type - comes with 2 chargers (2 batteries came with strobes, I paid $250 for addition battery).
    • Arm and clamp system as shown in pictures (1 currently, you will need a second).
    • Sync cables: 1 x single and 1 x dual/split (joins the two strobes to one port on the housing). (splitter cable $160.00)
    3. Modular 8 inch Dome for DLM and FL Systems, Product Number 5510.45: $200.00 (shipping $35)
    This item is in good condition. It was used less than 20 times. I just don't use it anymore. There are about 3 or 4 very minor scratches that have never affected the images taken due to diffraction of light in water - this is an acrylic dome, and therefore can be buffed out if you want.
    4. Modular Flat Front for FL Systems (2 available) Product Number 5510.35: $100.00 (shipping $20)
    5. FL Extension for Lenses Up To 4.25 Inches: Product Number 5510.24: $80.00 (shipping $15)
    6. FL Extension for Lenses Up To 5.1 Inches: Product Number 5510.28: $110.00 (shipping $15)
    I have pictures of all these items, I would be happy to email them to you (they are apparently too large to upload here. These items are listed on Ebay as well, so they may go that way as well...
  2. Hey. Were you able to use any zoom kit with the 8 inch dome port?
  3. PM sent
  4. Hey. Were you able to use any zoom kit with the 8 inch dome port?
    Hello,
    Yes. The Ikelite housing has a zoom gear/knob built in. Therefore, I used my 17-40 and 14-35 f4 with the dome.
    Thank you,
    Jonathan
