Flat port vs dome port - pros and cons?
Started by JeremyGelber ·
  1. Hi,
    I have both the flat port and the dome port for my Ikelite FL system enclosure. I dive with a Nikon D610 full-frame camera, and my last dive was done with a Sigma 50mm f/1.4 prime using the flat port.
    Are there optical advantages to using one over the other? I understand that the flat port effectively "zooms" images whereas the dome port will give a similar field-of-view to what I would experience above water. The flat port is obviously MUCH smaller and lighter, but apart from getting in and out of the water that won't make a huge difference to me.
    If I was to dive with a wide-angle lens, I realise I want to use the dome port. However, if I'm diving with a 105mm prime macro would I want the flat port to extend its reach or am I always better off using the dome port?
    The question really comes down to this: do I get better pictures in terms of the quality of the final image by using the dome port rather than the flat port?
    Thanks in advance for your replies, and explanations!
    Jeremy
  2. The dome port is (mostly) for wide angle. a dome port makes a virtual image (http://www.camerasunderwater.info/optics/dome-port-theory) that you then focus on. the image is curved not planar and is most suitable for wide angle lenses. The flat port is what you want for your macro lens setup, it comes with a bit of built in magnification.
    Bill
  3. What is not often stated is that the refractive index of water varies by wavelength of light. This results in chromatic aberration which can be seen even in a swimming pool. Behind a flat port the chromatic aberration is a function of the angle of view measured from the optical axis, i.e., the half angle. It gets much worse as the angle increases. Therefore one can only use flat ports with near normal focal lengths and longer. One can get away with a flat port with a 35mm focal length on the 24x36mm format for example. The non-SLR Nikonos 35mm lens used a flat port - this is why it was amphibious and not underwater only (all the non-SLR Nikonos lenses with focal lengths <35mm were under water only).
    The main purpose of the dome port is to restore the angle of view of the lens. This also results in the removal of the magnification (that you get with a flat port - see Bill's comment) and thus variability of magnification related to chromatic aberration. However, one needs to properly set up the dome port (correct amount of port extension). As well, one cannot avoid the field curvature of the virtual image. For example with a 105mm macro you would need to move the dome port some distance way from the front of the lens and you may lose some of the lenses macro capability. The resulting air space between the dome surface and lens could also be problematic in terms of rig buoyancy.
    Also important is the distance to the dome port virtual image is quite close. Most 50 1.4 lenses cannot focus close enough, i.e. at minimum focus (e.g., 0.45m) the lens is focused beyond infinity when behind a dome. The solution is to use a close-up diopter lens. These may degrade the image to the point of uselessness - it varies by individual lens design. For example I found that when using one with a 24-70mm zoom (min. focus of 0.38m) the result with single lens diopter was unacceptable. OK however when used with a two-element achromatic diopter except that the thickness of the diopter caused additional vignetting.
    Edited by Tom_Kline
  4. Thanks for some extremely useful information and great links from both of you.
