Nikon 85mm Micro
Started by mmakay ·
  • 13Posts
  • 13Replies
Nikon 85mm Micro
  1. I appears that not many people are using the Nikon 85mm Micro underwater. I'd like to hear from those that do use it or have tried it. Does it work well? Are there down sides? The f/3.5 max aperture is often cited as a concern, but I can't imagine it being too much of an issue with macro since I'm normally stopped down for DOF. Everything else about it seems to make it a fairly good choice.
  2. It is a very good lens - light and great value for money. It is not popular because it is for cropped sensor cameras only - meaning you would have to sell it if you switched to a full frame camera. For this reason most Nikon users choose the 60mm and 105mm, which can be used both on DX and FX.
    Here are three shots taken this year with the 85mm Nikkor:
    http://www.amustard.com/library/cache/40/SARD16_am-10438_750.jpg
    http://www.amustard.com/library/cache/40/SARD16_am-10644_750.jpg
    http://www.amustard.com/library/cache/40/SARD16_am-10677_750.jpg
    Edited by Alex_Mustard
  3. Hi Alex,
    so in qualitative things it is good?
    Just thinking because of weight reasons to buy it, its light and needs a leighter much port than my Nikon 70 - 180mm micro zoom...
    Regards,
    Wolfgang
  4. I am sure its optical quality is better than the 70-180mm.
  5. Hi Alex,
    have heard that on a full frame camera it is not performing so well as it was on my D300...
    Now its a D500...
    But that you can ceep some distance to the animal, helps sometimes ;-))
    So the zoom is a nice thing, but old and too heavy....
    Regards,
    Wolfgang
  6. Alex, do you find that the FOV afforded by the 85mm gives it any advantage over the 105mm in terms of framing/subject flexibility? How do the 2 compare in AF performance underwater? Those seem to be the biggest factors that make people recommend the 60mm over the 105mm ... but the working distance of the 60mm is a non-starter for me.
  7. Another lens with excellent performance and priced cheaper than the Nikkor 85mm Macro is a the Tokina 100mm Macro.
    Regards Mark
  8. I like the zoom flexibility of the 70-180 mm micro lens,
    but have found it soft on my D800E compared to the 60mm G and 105 mm VR
    Elmer
  9. I should point out that I'm not looking at the 85mm for cost savings. Compared to every other expense in this hobby (ports, housings, dive travel, etc. etc.) the cost differential of the lens itself is completely in the noise. If we were looking at lenses that cost $2000 or more, I'd be singing a different tune! LOL
    The potential advantages I see for the 85mm:
    1. Good working distance (way better than 60)
    2. Ability to make good use of wet diopters (way better than 60 / not quite as good as 105, but close)
    3. Small size = small port (same as 60)
    4. Somewhat more flexible in subject size than 105, though not as good as 60
  10.
    Sounds like an 85mm macro is in your future as it does fit in between the 60 and 105 nicely. I might have purchased the 85 had Nikon brought it out sooner. After going digital I bought the 60 and 105 D lenses (felt a need for AF for UW) and then the 105 and 60 AFS when they came out. As well I have the older manual focus 55 and 105s, the macro zoom, and the 200 medical lens. Thus my lack of interest in the DX macros, which came out more recently.
    A few years back I shot an entire diving trip to Maui with the 105VR using the D2X. Got some great shots of small reef fishes on that trip but it was a bit too narrow the day a White Tip Reef Shark and a moray were going around in circles in front of me! Even the 60 might have been too narrow for that. However I have taken half-shark pix with the 60 (the front half!). The 60 is pretty good for shooting APS-C format in more limited visibility too.
    Edited by Tom_Kline
  11. I am a 60 and 105 shooter since the mid 80s and just picked up a 85 and will try it at at Wakatobi for the two weeks we are there shortly.
    I'll report back in march.Ju]st bought all new lenses to see what get new stuff is like.I'm still shooting a cropped sensor D30 so the 85 will work fine.
  12. I loved that lens for my cropped sensor nikon camera .
    It was a new tool after all these years with the 60 and 105 option
  13. Agree with Alex. Use all three lenses. 105 is trickier to use. The 85 is a great lens on APS-C and doing super macro with it works just fine.
