o-ring grease
Started by Awagami ·
o-ring grease
  1. I've recently purchased the Neewer housing for the Sony a6000. I understand this is a rebranded version of the Meikon housing (cheap! cheap! cheap!). One of the differences between the 2 housings is that the Neewer version does not include o-ring silicon grease. So, I thought, no problem: I'll just go to the hardware store and buy a bit of silicon grease. That'll do the job, right?
    Well...subsequent research has revealed that there are different varieties of silicon grease, some of which may damage the o-ring. My question is this: what sort of silicon grease should I use? Where would I get that grease? (Meikon sells a grease, but they oddly do not ship to my zip code--I live in San Francisco, CA, USA.)
    Thanks, I appreciate any help you can provide!
  2. Interestingly, the Neewer company responded to the email I'd written them requesting information on how to get o-ring grease with this: "...o-ring grease is not necessary. But if you need it, you could order the grease elsewhere."
    Sigh. But Meikon told me that they'd ship to me if I made at least a $20 purchase. So, I bought three tubes of grease from them--I'll be thoroughly lubed up :-)
  3. Probably doesn't matter since you already bought some, but I have a container of Trident Silicone Grease that's lasted for years and years.
  4. Ah, but is Trident Silicone Grease good for the Neewer/Meikon o-rings? That's what puzzles me: how can any particular silicone grease be better or worse for a different manufacturer's o-rings? Aren't they all made of the same materials? I mean, I understand that a petroleum-based grease would cause a rubber o-ring to decay, but....a silicone grease?
