Canon 5D mk II camera and Seacam housing and ports
Started by bradsheard ·
  1. For sale, excellent condition Canon 5D mark II and Seacam housing outfit. This is a (nearly) complete setup including camera, housing, 2 ports, extensions and gears—all you need are lenses and lighting.
    The Canon 5D mark II is a fantastic 21mp full-frame camera. The camera is in excellent condition and includes charger and one battery. The Seacam housing is a fine piece of engineering and is in excellent condition. Housing is wired with dual Nikonos strobe bukheads and has and two Ultralight balls mounted on top. Included ports are a glass wide-angle superdome (this is the superdeep version, identical optically to the normal superdome, but slightly thicker and rated to a depth of 100m). The port has quite a few cosmetic scratches on the lens shade only, the glass is nearly perfect (there a 2-3 extremely fine scratches which are very difficult to see and have no effect on picture quality at all—you would have a hard time finding them unless I showed you where to look). Also a macro port that is essentially perfect—only used twice. Also included are 3 port extensions: 25mm, 30mm and 35 mm. Also several lens gears: focus and zoom lens for Canon 16-35mm f/2.8 II, focus for Canon 14mm II and Canon 15mm fisheye. Note NO lenses are included.
    $3000, Continental US only
  2. Hello
    I need a superdome and would be very keen to buy yours if you are willing to separate and post to Australia
    Please let me know if you would consider doing this
    Jules
  3. Sorry, looking to sell the whole package.
  4. If you are unfamiliar with Seacam housings, please check out the USA dealer website (Stephen Frink): http://www.seacamusa.com
    Seacam housings are extraordinary quality….I've owned Aquatica, Seacam and Nauticam housings over the years, and while they all make excellent housings, Seacam's are truly extraordinary.
    Asking $2500 for complete package
  5. Hi There.
    Are these items still available?
  6. Yes they are still available
  7. Still available? What will I need to complete this set to get in the water and shoot? I'm purchasing for husband for birthday and fairly clueless.
  8. Hi, yes this is still available.
    There are no lenses included, so you would need to supply a lens. And no strobes or lighting, so you may need that as well, depending on what sort of shooting your husband wants to do.
    Is your husband an underwater photographer already? Do you know what kind of subjects he likes to shoot? Wide angle or macro? Reefs, critters, shipwrecks?
    I'm not trying to discourage you at all, but this is a fairly big purchase and depending on what type of photography your husband is interested in might influence what type of outfit you/he would purchase.
