FS: SmallHD 501 HDMI Monitor and Nauticam NA-502H housing
Started by Hannes_taucht_ab ·
  • 13Posts
  • 13Replies
  1. Hello people,
    I'm selling my beloved SmallHD 501 Monitor and the Nauticam Housing. Everything is in very good, almost new condition and only 1 year old. The package includes the following:
    - SmallHD 501 Monitor (zero scratches on the screen, minimal wear from inserting into the housing)
    - Nauticam NA-502H (zero scratches on the window, otherwise minimal wear)
    - Nauticam Monitor Hood (vital in bright conditions!)
    - 2 main O-rings for the housing
    - 1" mounting ball for attaching the housing to a standard arm system (not shown on the pictures)
    - vacuum pump (the vacuum system is pre-fitted to the housing and has a brand new battery)
    - 2 HDMI cables to connect the Monitor housing to the camera housing bulkhead (750mm)
    - 90 degree HDMI-HDMI adapter for inside the housing
    - HDMI bulkhead and socket extension for NA-GH4 (might work with other housings, too - please check)
    - 2 micro HDMI cables to connect the camera to the bulkhead
    - 4 LP-E6 batteries for the monitor (2 of them can be attached at the same time and last more than 2 hours)
    - dual charging adapter (connects to a micro USB charger - NOT included)
    - micro HDMI to HDMI cable to connect the monitor to the camera when not in the housings
    - hot shoe mount for out-of-housing use
    - Nauticam O-ring grease
    - All screws
    If you bought all of this new, it would total to about £2900. My asking price is £1800.
    I'm only selling because I need a more lightweight setup now. The monitor is absolutely amazing and has served me very well on about 50 dives!
    All of this can be picked up from Preston, UK or shipped anywhere in the world provided you're covering the cost.
    Edited by Hannes_taucht_ab
  2. Price bump £1700
    Sent from my HTC 10 using Tapatalk
  3. Bump
  4. Price bump £1600
  5. Bump... Come on people this thing is amazing!
  6. Right, final price £1500. That's about 50% of the brand new price :)
  7. Bump
  8. Bump :)
  9. Price bump £1300
  10. Bump :)
  11. Bump
  12. I would take it for 1300, is it still available?
    Edited by textilet
  13. This is no longer available.
