Need settings for Panasoni GX85
Started by leepix ·
  1. I am getting a GX85 in a Nauticam housing and wondering is anyone has a good list of settings? Most likely based on Pany GX7? I shoot with Pany mm FE and do mostly CFWA and fish portraits with reef "structures" in between.
    suggestions pls?
  2. Are you going to be shooting mostly pictures opposed to video? I've just started shooting photos and primarily do video. For photos I've been shooting in standard picture profile (with default levels), AWB, 1/125 SS, and varying f-stop and ISO for depth of field needed. Some sample pics:
    9615d8d6e6193852529200d0ff13dbcc.jpgb45c1621dd5d8a3fe22971a971389cbf.jpg349f926117ec438e78d3fce8d921861a.jpg964c0fb0b052090f6f6bcb6a5e9d1143.jpg
    For video I've also been shooting in standard picture profile (with default levels), MWB, 1/60-1/30, and varying f-stop and ISO as needed ( a lot of ISO 800+ in our dark waters)
    Here's my first video with the camera:
    Edited by ScubaBob
  3. I suspect the setting will not be very different from other MFT including the GX7
    With the 8mm FE depth of field is not an issue. I usually shoot RAW (picture profiles and other settings are irrelevant) ISO100 shutter 1/125 Aperture f/5.6. There are no major benefits closing the aperture and beyond f/8 the lens does not perform well. Obviously if you do sunburst you may need to go all the way down to f/22 considering the GX85 syncs at 1/160 max.
  4. thanks I will be shooting stills mostly in CFWA and yes some sunbursts. Thanks for info.
