Nauticam TTL flash Trigger with YS-D2
Started by michaelgeyer ·
  1. Hello,
    whats the best setting for the Sea&Sea YS-D2 when i will use it with the Nauticam TTL flash trigger?
    I think, i will set with the camera which modus i will use...manuell or TTL.... so which settings i should do on the flash?
    Edited by michaelgeyer
  2. Camera?
    Bill
  3. A Canon 5d Iv
  4. If the camera is set up to TTL, then you set the strobe the same way. For manual, set the camera to manual flash (1/64 or so) and set the flash to single lightning bolt.
    Bill
  5. Perfect, thank you...
