Is there a "multi purpose" recomanded lens for nikon D7200?
Started by Eitan Ben Tsvi ·
  1. I am actually looking for a "point and shoot " zoom style lens with macro capabilities,
    for my nikon D7200
    a lens, also with proper wide ...even without the dome effect
  2. You are asking for everything without realizing that there are compromises to be made.
    I assume you have very clear water, otherwise wide angle won't be of much use.
    For wide angle you might want to look at a Tokina 10-17 lens but you will need a dome. And to get your desired macro effect you will need to get very close to your subject.
    For macro? get a macro lens. For your camera Nikon has 4 choices. 40mm, 60mm, 80mm, 105mm All are good lens. You will need a suitable port. The longer the lens the less need to get close to get the image you want but you get less of a wide angle for non close up photos.
    Where I dive the water is reasonably clear, at times. I use a D7000 and a Nikon 18-55 lens. Somewhat wide angle when used with a dome port, sort of close up when zoomed out to 55, and its a reasonable compromise lens. Sometimes I have used my old 55 Micro Nikkor, manual focus for close ups. But of course that is when I see an opportunity for a wider angle lens.
  3. You are asking for everything without realizing that there are compromises to be made.
    You are right of course....but let me try to explain better my question
    first of all I am already working in the same concept you describe...the "Interchangeable" way, with the Sony A6000 and 90mm macro (fantastic!) lens , and 10-18 wide angel lens. both are sony.
    I like this set up very much!
    but I don't have fisheye...with Sony
    So I decided to add Nikon D7200 = only because of the tokina 10-17 fisheye lens.( My housing let me use 2 cameras or more)
    I am new to nikon, and don't know about setup options ....
    I don't need macro lens or wide angel lens or fisheye lens. I already use them
    I simply looking for as much as possiable flexiable lens...to try and see what are the possibilities
    Now I see I post it by mistake on the wrong section :)
    Sorry.....
    Managers = Please move it ...if possible ?
    Edited by Eitan Ben Tsvi
  4. Tokina 10-17 for wide
    Sigma 17-70 for general purpose--a compromise between macro and wide
    Nikon 60 for macro--great but short focusing distance
    Nikon 105--best for macro
    Will need appropriate ports, domes and extention tubes.
