Recommendation wide angle lens for Sony RX100V in Nauticam housing an Bayonet Mount System
Started by tdphoto ·
  1. Hi,
    For a friend i need a recommendation for a wide angle lens for his new Sony RX100V in the Nauticam NA-RX100V housing with the Nauticam Bayjonet Mount System.
    Which lens works with the Bayonet Mount System with 24mm and which lenses have to zoom in for working?
    Thanks for you help!
    Greetings from Switzerland,
    Tino
  2. The Nauticam WWL-1 is probably the go to for that system.
    The other possibility is the AOI UWL-09, but that's a 67mm screw thread.
    They are both supposedly compatible with 24mm equivalent cameras and you shouldn't have to zoom to eliminate vignetting.
