Nikonos SB105 with 1.25" ball arm = help
Started by Walkinglessa ·
  1. Hi! I have two Nikonos SB105 with 1.25" ball arms, in an Ikelite housing (D800). Since I don't get along the original tray, I'm going to another one has the same ball arm style, but with 1" balls. Anyone has a clue of how to connect SB's on 1" ball arm? Thanks!!
    Sorry! I meam NIkon Sb105; the flash :)
  2. ULCS AD-103 Adaptor for Nikonos SB-103, SB-105 Strobes
    from Reef Photo.
    Bill
  3. depending upon the arms you are planning to use, you could also convert your SBs into a YS mount.
    Sea & Sea SA-V adaptor for SB103 / SB105 can be found on eBay. But this only works if your "last" arm ends with a YS mount (mine do). This scheme eliminates a ball clamp close to the strobe - but replaces it with a YS screw clamp.
