Green
Started by Murky_Waters ·
Green
  1. Green
    All of my pictures come out very green. I am in Michigan, so there is a lot of alge in the water that tints it. Could this be corrected by changing the white setting on the cammera? I use a Stylus 300 with the Pt-016 housing.
    Thank you
    Jeremy
  2. I'm not familiar with your camera. If you can set a custom white point then do so if not shoot it with a florescent light setting. This will remove some of the green. Photoshop is your best bet to take all the green out.
