inon UCL 100 67mm +10 compatible?
Started by craig nelson ·
  1. Hi all
    Do you know if the Inon UCL 100 +10 will work with a 67mm flip on an SLR system ? 105 macro
    Can't find out much information or do any testing.
    Regards
  2. Hi Craig,
    Inon offer two fittings...bayonet and 67mm.
    If it has a 67mm thread it will fit. However, as it is designed for use with compact cameras, the image quality is not great when used with an SLR..
    All the best
    Adam
  3. Hi Adam
    Thank you , hope your well and all is good.
    I thought that might be the case. I'll grab a subsee or FIT 67mm
    Regards
    Craig
