Radio strobe trggers don't work underwater
Started by Metaluna ·
  1. Radio waves don't travel very far underwater leaving conventional multiple flash setups without the benefit of radio controlled speedlights but I would like to mention since ultrasound travels very well underwater it's worth exploring ultrasound controlled underwater flash photography
  2. I think the issue will be to convert the ultrasound to either photons or electrons reliably. I think it could be done but I can't find any existing technology that might be "housable"
    BIll
  3. The delay on ultrasound needs to be considered. You would likely be looking at a shutter speed maximum of 1/50th once you are more than a couple of metres from the flash. As Bill says, there is a shortage of commercially available components unless you know some submarine guys.
    I have done some research into better transmission options for triggering off camera strobes (dry cavers use infrared which also doesn't work underwater) without anything looking particularly feasible. Ultrasound is probably the closest and would require some kind of delay in the circuit to keep the off-camera strobe and the shutter in sync.
    Ultraviolet laser beams are tempting but a bit carcinogenic. Long cables are impractical in most scenarios. Shooting bulb with manually triggered off camera strobes works in complete darkness but is a game to get good composition when you can't see what you're doing. It might be worth trying a visible light trigger on a delay circuit to remove the on-camera flash from the picture - it's on my to do list, one day.
