Aquatica Canon 5D MKII Pro housing, 2 ports, 2 DS161 strobes
Started by acapulco ·
  1. For SALE
    Hello I have been left in charge of finding my buddys Aquatica Canon 5D MKII Pro housing kit a new home.
    I have her listed on ebay but we would rather her go to a home where she will be loved so we found yall.
    Im looking to sell off the U/W kit as a whole for right now. I also have the camera kit up for sale but im happy to break that up.
    The whole U/W Kit $4200.00
    The camera kit $850
    - recently served by Backscatter and has been used about 15 times since then.
    - moisture detector
    - camera mounting plate
    - 100% functional, normal wear and rubbing around edges. Never dropped or flooded
    Aquatica 8inch dome port w/
    -sun shade port cover
    - locking port extension 2.5 in
    - A few super light scratches on the dome and the body has typical cometic wear
    ( was used with a the 16-35mm 2.8 L usm)
    Aquatica Regular auto focus flat port
    - 1in extension
    - port cover
    - lens in great shape no noticeable skuffs
    -body has typical cometic wear
    (used with the 100mm macro)
    Aquatica view finder
    - soooo awesome to use
    - bit of cometic rubbing around the edges but works perfect.
    Extra Aquatica stuff:
    - paperwork / lens chart/ operating manual
    - O-Ring rebuild kit for housing
    - 2 zoom gear rings for a canon 16-35mm / 17-40 mm
    xit 404 ring kit
    -canon 100mm macro focus ring kit CAN100
    2 Ikelite Digital Substrobe 161 w/ movie light #4061
    - 2 Li-ion battery packs
    - 2 chargers
    - strobe cable to connect to housing
    - paper work with lots of extra o-rings
    -on lenes defusers
    - perfect working order
    Ultra light double ball arm segment and clamp
    2- 8inch
    2 -12inch
    6 - new style clamp with 1/4 - 28 thread
    4- stix buoyancy floats
    Other:
    Novus plastics cleaner
    small inspection flashlight
    Pelican cases 1600
    Camera Gear is :
    Canon 5D MKII with 3 batterys and charger
    - good condition, basic cosmetic wear
    16-35mm L2.8 lens
    - works perfectly but has some fungus in the inside elements
    100mm macro
    - works perfectly but has a little fungus in the inside elements
    Battery grip / Flash both work perfectly
    Edited by acapulco
  2. Would you be willing to sell the dome separately? If so, how much?
  3. Hi, if you split, I'm interested in the arms and clamps. How much for the two pairs?
