Knowing your in Rear syc Nauticam Housing
Started by Crayfish ·
  1. Hi I currently have a Nauticam D800 housing the problem i have come across is there is no way of knowing when you have change your flash to rear syc.
    Before I had a Ikelite housing and you could see the top display and change it from front to rear curtain.
    But now if I change it I have no idea if it's on Front, Red Eye or rear as it wont show in the viewfinder.
    Does anyone know if there is something in the menu you can find out or is it just a matter of setting it before a dive and leaving it on?
  2. Press Info button to see Info screen on rear LCD. Flash mode shows at left, second row down (if pop-up flash is up, or a strobe is connected electronically via the hotshoe)?
  3. Press Info button to see Info screen on rear LCD. Flash mode shows at left, second row down (if pop-up flash is up, or a strobe is connected electronically via the hotshoe)?
    Yes, definitely start getting familiar with the info button. Extremely useful underwater.
    I once had a problem with my CF card having a read error at the start of the dive. Took a while, but with help of info button managed to find out how to change settings to write to SD card instead of CF.
  4. Cheers! Thanks so much for that, I will have a play around with the settings tonight.
