DS-125 & Canon A80
Started by KimInNB ·
DS-125 & Canon A80
  1. DS-125 & Canon A80
    I have just recently started using a strobe with my consumer digicam and most of the time I love it.
    However, this past weekend I ran into a problem where I was trying to photograph a winter skate. No matter how far I turned the manual controller down, the strobe overwhelmed the photo. I finally gave up and turned off the strobe, which resulted in a photo I can post-edit.
    Anyone have any solutions for me with this? What was I doing wrong? What can I do to stop this problem?
    Here are examples of the various photos at the various settings. The last photo is the one with the strobe off.
    http://www.pbase.com/kiml/strobe
  2. Hi Kim,
    You'll need to let us know what shutterspeed and f-stop you were using for the photos.
  3. It's showing as a 1/60 shutterspeed and f/2.8 in the exif. I use the camera on basically auto - I don't set the shutterspeed & f-stop manually.
  4. There's your problem. At f2.8, you can light the shot with a candle.... You need to set the camera in A or M mode and set a higher f-stop if you wish to use your strobe. You will get MUCH better results that way.
    HTH
  5. Thanks James!!
    I'm basically a point-and-shoot kind of girl, but I checked out the manual and guess what!!! It's not difficult to set a higher f-stop. I'll try it next weekend in Cape Breton!!
  6. Glad I could help.
