Sea & Sea VF45 (45-degree 1.2x) Viewfinder -- Worth $1000?
Started by Djuna ·
  1. Greetings!
    I'd be really curious to hear from anyone using this if they feel it's worth the investment.
    Thanks!
    Djuna
  2. And more specifically, can anyone compare this to the Inon 45-degree viewfinder for Sea & Sea?
  3. I have the Sea and Sea 45-degree. I like it very much. I believe it is identical to the INON. Must be same manufacturer as they look the same. Check to see if the mount s the same for the housing. My Sea and Sea has two small pins that fit into the plexiglass indents of the MDX housing.
  4. I would get the INON and save $500 personally. They look similar but not quite identical to the Inon and they might have the same innards.
    Bill
