Aquatica AD500 / Problems with flash (Nikon SB-800)
Started by ClosedCircuit ·
  1. Hi Everyone,
    I have moved on from a Nikon D300 in a Subal housing to a D500 in a brand new Aquatica AD500. Everything works beautifully, with the exception of my flash. I am banging my head trying to find a fix and was wondering if any of the tech savvy photographers on the forum might take pity on me and offer some advice.
    The flash is a Nikon SB-800 in a Subal housing connected via a Subtronics cord (Nikonos connectors). The AD500 has two nikonos-type sockets.
    When connected to the Aquatica AD500/Nikon D500, I have two issues :
    1. If I wait for more than 30 seconds or so between shots, I have to take one or two pictures to « wake-up » the flash before it starts triggering properly – i.e. lots of missed opportunities
    2. TTL doesn’t work (I normally shoot in manual but TTL is handy when shooting macro or fast moving action).
    I have used the SB-800 with my old Nikon D300 in a Subal housing for many years and never had these issues. Also, both the flash and the sync cord work perfectly.
    All four flash switches inside the AD500 housing are down (I've tried to put them up but it makes the situation worth).
    Many Thanks !
    Best regards
    Edited by ClosedCircuit
  2. Hi Everyone,
    • If I wait for more than 30 seconds or so between shots, I have to take one or two pictures to « wake-up » the flash before it starts triggering properly – i.e. lots of missed opportunities
    • TTL doesn’t work (I normally shoot in manual but TTL is handy when shooting macro or fast moving action).
    Many Thanks !
    Best regards
    Sorry can't help with the flash issue but very interested to hear how you find your new set up - I'm considering same move (subal d300 to aquatica d500). Do you have a magnifying viewfinder?
    Sent from my ONEPLUS A3000 using Tapatalk
  3. ......
    If SB-800 TTL does not work, that means wrong wire connection somewhere. Pinout of any part is different, or any wire /contact is damaged.
    Necessary to check wiring diagram, connectors, board, cables, bulkheads, etc., - carefully step by step.
    Edited by Pavel Kolpakov
