Ikelite discontinues D500 200FL four lock housing
Started by water buffalo ·
  1. Ikelite announcement
    Not really an announcement, more of a statement. If you are looking for one there are still a few around (eBay, Amazon, etc.).
    Looks like I ordered one just in time. Makes me sad to think this will probably be my last housing. $800 for a port just ain't gonna happen even if it can be used with multiple lenses.
    So far the D500 is the only camera I see the message under. Maybe there is just a problem with the system and I am overreacting?
    What do you think? Did I miss some news somewhere or is my favorite budget housing manufacturer going high end?
    Edited by water buffalo
  2. I just looked and they have discontinued the 5d four lock housing as well. When I saw the release of the new dry lock system I knew the days were numbered for the old system. I understand all of the benefits of the new system and if they did not go forward with it they would have lost out. Today’s lenses are getting big as we are demanding better quality glass and those just don’t fit the smaller diameter of the old system. The bummer for us Ikelite fans is now the need to replace our ports with the next housing purchase. For me that would still be far less expensive than buying an aluminum housing and the ports and zoom rings to go with it. But as I just set myself up with a 5d3 I won’t be purchasing another housing for some time.
  3. Just a quick add to this. I was just reading the release notes for the D850 housing and it says you can remove the drylock system and install the old locks. They say you can't switch back and forth but the option is there for someone with a large portion collection and no need for the wider opening of the dry lock system.
