Lock the dome or not? (Canon 8-15mm and Ikelite 8'' dome)
Started by KSund ·
  1. Hello
    I've got an Ikelite housing for my Canon 6D.
    Unting now, when I've been using my Canon 8-15 F4L-lense, I've only used it at 15mm.
    Then I could use the shade for the 8 inch dome, wich are were the locking mechanism to prevent the dome for rotating is mounted.
    The locking mechanism is a small bracket, that's mounted on one of the set pins for the shade.
    I just got my zoom-gear to be able to use the lense at 8mm, which is sirkular fisheye. To prevent the shade to be visible, I have to remove the shade from the dome.
    The problem is: When I remove the shade, it's nothing to prevent the dome from rotating, and eventually fall off.
    How do you guys handle this problem?
  2. If your using a vacuum system, your port will be locked without a lock. the underpressure will keep it firmly in place.
    Edited by bubffm
