AquaTech ND-7 Underwater Housing for Nikon D700
Started by TimKag ·
  1. AquaTech Underwater Sport Housing for Nikon D700
    Condition: Very good. Minor signs of usage. Seals tightly. All buttons function properly.
    The camera fits in the housing like a glove. This allows the housing to look, feel, and operate like your camera, using tactile controls instead of levers and gears. The epoxy construction makes the housing lightweight and durable. So the ND-7 is perfect for working in and around the water, up to a depth of 33' (10 m). The size and weight provide superb handling on the surface. This allows you to shoot surf and sailing photos while being right in the water. Camera installation is quick and simple. The dependable controls are conveniently placed at your fingertips. Compatible with an assortment of interchangeable lens ports allowing use of different lenses including long telephoto zooms. This feature makes the housing suitable for surface work, as opposed to housings designed for diving that only allow use of wide-angle and macro lenses.
    https://www.ebay.de/itm/192354016608
  2. sold
