Olympus 7-14mm F2.8 on PT-EP10
Started by Timz ·
  1. Hi everyone,
    I'm using Olympus E-PL5 with Olympus PT-EP10 Housing.
    Recently, I want to buy an Ultra WA lens. The highly reviewed Olympus M.Zuiko 7-14mm F2.8.
    However, I couldn't find any port that matches my housing with the lens.
    I know Zen made a port for the Pana 7-14mm.
    I also know that isn't a problem with Nauticam housing.
    But I will prefer to buy the Olympus 7-14mm over the Pana.
    Anyone came across this dilemma? Care to share?
    Thank you in advance.
    Tim
    Sent from my SM-N950F using Tapatalk
  2. I believe the problem is the smaller port size used on the Pen series housings, the Olympus 7-14mm is just too big to fit in the ports. The Panasonic is a much smaller lens so you are bale to use it with the Pen series ports. Believe it fits no problem on the larger ports like used on the EM-1 housing.
    The Nauticam housing requires you to install the camera in the housing then install the lens on the camera and install the dome port over the lens, again the lens/gear is too big to fit through the N85 port on the Nauticam, from inside the housing. The specific requirement is for the N85-N120 adapter and extension ring and the N120 170m dome port.. All due to the large OD of the lens (79mm)
  3. I believe the problem is the smaller port size used on the Pen series housings, the Olympus 7-14mm is just too big to fit in the ports. The Panasonic is a much smaller lens so you are bale to use it with the Pen series ports. Believe it fits no problem on the larger ports like used on the EM-1 housing.
    Thanks mate.
  4. Hi Tim
    I don’t think that combo is possible with the EPL Series :-(
    I know that AOI make a port for that lens for the OMD housings
    https://oceanleisurecameras.com/aoi-dlp-08-8-dome-port-for-omd-housings
    But I think the port fitting is different between the EPL and OMD housings.
  5. Hi Tim
    Thanks. But Sadly, the PT-EP13 Housing for OMD-EM5 MKII utilizes the PEN port system. Which means the E-M5 mkii is not able to use this port. T.T
