Dive and See DNC-5A(H1) Monitor clip playback
Started by benedika ·
  • 15Posts
  • 15Replies
  1. Hi,
    a question for all DNC-5A(H1) users.
    Do i have a clip playback on this "HDMI output only" monitor?
    If not, i got the wrong monitor or do i have to change settings?
    I went through the cams and monitors set up without getting a playback.
    Thanks!
    Alex.
  2. Hi,
    Thanks!
    Alex.
    I tried it again. Playback is running now.
    I tried it two times before-no playback, only a black screen. The black were my clips with the neopren cover on the dome.
    How embarrassing! :-)
  3. @Nick: It is not always easy
    Do you guys manage to get the cam in energy save mode while the monitor is connected?
  4. Unfortunately, the GH5 will not go into energy save mode as long as a monitor is plugged into the HDMI port, be it a DNC, SmallHD or whatever....
    I find that slightly annoying as well, if you scroll some of the usual cam-forums, we are not alone. Not sure this is fixable with a firmware update....
  5. Unfortunately, the GH5 will not go into energy save mode as long as a monitor is plugged into the HDMI port, be it a DNC, SmallHD or whatever....
    ...and there goes another email to the Pana support. Hoping a minority can have input on new software updates...fingers crossed!
  6. Another question for you guys.
    How is your monitors battery led status working?
    At 2 1/2 led my monitor shuts down
    I think i remember from the monitor manual "flashing led" as a low battery warning.
    Hows yours?
  7. Sounds unusual. But then I usually charge the monitor when it approaches 2LED‘s on the indicator anyway...
  8. Sounds unusual. But then I usually charge the monitor when it approaches 2LED‘s on the indicator anyway...
    me too, but i was kind of surprised the first time as it shot off at 2 1/2.
    Is yours working until one led or even flashing led?
  9. Id need to try out. never actively had it that low. I even change my cam-battery before it reaches one bar.
    Edited by bubffm
  10. Id need to try out. never actively had it that low. I even change my cam-battery before it reaches one bar.
    Yeah, thats something you learn real quick
  11. BTW, was it during your ice dives that the monitor battery died early? With those temperatures, that would not be too surprising...
  12. BTW, was it during your ice dives that the monitor battery died early? With those temperatures, that would not be too surprising...
    I know but, but it was in the Maledives too.
    Anyway, i did a test a few days ago. During the test the led went down to one, and the monitor runs for 3:50.
    So everythings fine.
  13. ...and there goes another email to the Pana support. Hoping a minority can have input on new software updates...fingers crossed!
    Did you get an answer to this?
  14. Did you get an answer to this?
    I didn't write a request in this matter.
    But i know from an other request (change timelapse settings via app) i have sent, you will get a standard answer "we'll forward your request to our team"..a.s.o
