Rokinon 7.5 mm m4/3 fisheye
Started by bremner ·
  1. Is anyone using one of these manual focus fisheyes in a housing? I guess you'd not have much control with the manual f-stop but keeping focussed at infinity is probably fine for all non-macro use. Physically it's pretty small, about the size of the sigma 60mm.
  2. Is anyone using one of these manual focus fisheyes in a housing? I guess you'd not have much control with the manual f-stop but keeping focussed at infinity is probably fine for all non-macro use. Physically it's pretty small, about the size of the sigma 60mm.
    Hmm, interesting question. I've never put mine on my camera in the housing. Might try that (in my house) and see how much port it sees.
  3. You would want to have it focused closer as the virtual image in a dome port even at infinity is very close to the dome.
  4. Hmm... any dome available for that lens??
    If it's anything shorter, i am not sure if anyport will fit the lens without having the port visible in the image
    Sent from my SM-N950F using Tapatalk
