Starter tray + strobe arm
Started by bremner ·
  1. I'm looking for a tray+arm to to attach a small strobe (inon S2000 or S&S YS01) to an Olympus PT-EP13 housing.
    I see most of the "starter packages" using some kind of flex arm on a polycarbonate or lightweight aluminum tray .
    For roughly the same price, Meikon [1] is selling a basic single segment aluminum tray + arm.
    This seems like the kind of thing where a lesser known manufacturer might be a reasonable choice. Aside from weight (I guess the polycarbonate setup is lighter), any other considerations/opinions?
    [1] https://meikon.com.hk/collections/aluminium-tray-and-handle-for-underwater-camera-housings/products/camdive-black-aluminium-diving-handle-for-underwater-camera-housings-advanced
  2. I would use a flat AL tray with holes in each end to mount which ever arm system you choose. I don't think the articulated knuckle arms can be locked in tight? ULCS and Ikelite have many different parts to put together.
    The little extra weight a metal tray would add, also balances the rig so its upright.
  3. Where are you located? I have a ULCS handle and flat tray sitting around that I could sell cheap. You'd still have to add a pair of clamps and an arm, though.
  4. @Vondo I'm in eastern Canada (E3B 1N9). Not sure what the postage would be like.
  5. I'm looking for a tray+arm to to attach a small strobe (inon S2000 or S&S YS01) to an Olympus PT-EP13 housing.
    The Meikon/CamDive one piece tray/handle is simple, robust, cheap.I have one on my Olympus TG-4. It comes with a 1-inch ball.
    I'd avoid the articulated arms. Several people I know have invested in them and then stopping using them.
  6. The Meikon/CamDive one piece tray/handle is simple, robust, cheap.I have one on my Olympus TG-4. It comes with a 1-inch ball.
    Which articulated arms do you mean? The flex arms, the ball+clamp arms, or both?
  7. Which articulated arms do you mean? The flex arms, the ball+clamp arms, or bo4th?
    The locline stuff.
  8. The locline stuff.
    OK thanks, that's the kind of feedback I was interested in.
