Rx100 V white balance
Started by Nico_H ·
  1. Hello!
    I just bought the sony RX100 V and was wondering if the setting "Underwater Auto white balance" is good enough or if I should consider getting a filter.
    any advice is much appreciated :)
  2. Hi Nico
    I have been using the RX100 V for about 4 months after previously using the MkII and MkIV.
    My experience is that any model of the RX100 does a poor job of auto white balance.
    I tried the UW white balance and the color temperature jumps all over the place - this is a big issue when shooting video which is my main use for the MkV.
    As I dive in shallow water I now set white balance to daylight, at least it will then be consistent and can be adjusted in post where necessary.
    From what I have read doing a manual white balance with the RX100 is not very successful either.
    Other than that it is a superb camera - the focusing ability is amazing.
    I recommend using a fixed white balance - choose a color temperature you find works best.
    Neil
